Joined: 8/10/2020(UTC) Posts: 7  Location: SD Thanks: 1 times
Hello!
I have set up a ticker that pulls data from a google sheet and scrolls through the list. However, it pulls one data cell at a time. Is there a way for me to show more data in the ticker at once, or remove the space so each section of text doesn't feel disconnected? I have looked for some information on the Format {0} section of the data sources options but have not found any documentation. Could a setting there be changed to accomplish this?
Thanks!
Joined: 12/27/2012(UTC) Posts: 5,535  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
change the ticker replace (content) option to add ( title/ticker settings)
Originally Posted by: doggy  change the ticker replace (content) option to add ( title/ticker settings) Thank you for the quick response! Could you elaborate on what you mean, I am not following.
when you want several items following one another to be seen (or actually follow one another visualy) you have to set the settings of your ticker to add instead of the standard replace
Ticker settings can be accessed by clicking on the little clock at the top of your title settings (see helpfiles) when you have selected the ticker item to set
for letting data follow each other from you data source set it to auto next
Excellent! Thank you much!
