dperaltajr
#1 Posted : Friday, February 5, 2021 8:07:45 AM(UTC)
dperaltajr
Hello, would be great if there was an option to put a "Failover" stream path for SRT encoding (or even other streaming output options) in case that path happens to die/disconnect.
mavik
#2 Posted : Friday, February 5, 2021 8:03:58 PM(UTC)
mavik
SRT in it's design should be stable. But if you cut the wire you should think of a way securing your connection as it has nothing to do with SRT directly. Depending of the Router you could use bonding or a second route once the first fails. Please be aware that the connection will break if you change the route on a failover. Only bonding will allow a continued connection.
RichDanby
#3 Posted : Friday, February 5, 2021 8:07:21 PM(UTC)
RichDanby
Was thanked: 29 time(s) in 26 post(s)
The SRT library is being worked on to allow multiple connections to transfer a stream, with connections allowed to come and go during the stream. Hopefully that functionality will be usable from vMix once it is ready.
SRT Groups
