-TA_
#1 Posted : Tuesday, February 2, 2021 4:54:46 PM(UTC)
-TA_
Hi!
Is it possible to to above scenario with new v24 IR ? And if possible good hints would be awesome
Lets say I have 3 angles replay 15s and I start to run angle1
and change to angle2 so replay continues dynamicly from cut point and won't start
at begin of angle2. and then cut to angle3. Hope I explained so you understood :-)
As now in v23 this is not possible as far as I can see.
Reg. Tommi
xaver
#2 Posted : Tuesday, February 2, 2021 6:00:52 PM(UTC)
xaver
you only have to change the angle during playback (press 1,2,3 near by the "P")
