Southwood Church
#1 Posted : Tuesday, February 2, 2021 7:07:29 AM(UTC)
Southwood Church
So I'm a complete newbie at this - so not sure what I've done wrong.
We are a small church and are set up using vMix with an incoming PTZ camera, Behringer Sound Board and Easy Worship 7.
We started two weeks ago and things worked fine. But this past week, our Easy Worship output isn't working right and I'm not sure where we went wrong and if it is a vMix issue or an Easy Worship issue. We run our in-house on a separate computer running the same Easy Worship 7 loaded up with the same worship songs and PowerPoint slide decks.
The problem is that when we click on the song slides (which are a theme set to a transparent bottom thirds text overlay) they display fine on the output in vMix. However, when we click on the PowerPoint slides, we just get a black screen. Where we used to see the slides fine. On the in-house computer, it still works fine and displays everything properly so it leads me to believe it's something between the vMix and Easy Worship. Just not sure what. I've tried reading troubleshooting tips in Easy Worship and on here - I've made sure vMix is updated, restarted the computer, deleted and reinstalled Easy Worship, tried different PowerPoint slide decks (including ones that worked the past few weeks). Nothing has seemed to fix it.
We are running PowerPoint through 365.
Any tips?
I've thought as a last resort I could save my slides as jpegs and pull them into Easy Worship that way, but then I wouldn't have the transitions and such. And we tried just running PowerPoint directly as an input into vMix but then for some reason they transition super fast.
