I have I7 10th gen and RTX3070 and in 4K30p project I get GPU Overheated and all videos ane BM card are lagged. Render time is about 40 - 70ms. When I append same "Save" to new clear project, problem is gone with same resources and same settings. Its not good solution, because I lost linked xls and shortcuts.
Im using DeckLink 8K Pro 1x 4k in - 1 external (fhd) 1 record. (4k)
Where is problem?
Joined: 7/28/2019(UTC) Posts: 351  Location: Santa Rosa Thanks: 1 times Was thanked: 53 time(s) in 51 post(s)
Check for the latest driver for the GPU. Only the very latest works with VMix.
Yes, I have acutal drivers.
Problem is with project. When I "append" project to newone, everything is ok.
