Instant Replay
Instant replay Exporting
Is there anyway to export an events list from instant replay as a single clip with transitions?,
We have tried exporting the events list as a single clip however this replaces all the transistions with cuts which make it look messy. is there anyway to change this?, Currently we are having to play the events list out to ourselfs and record to make a single clip with transitions which isn't ideal.
Thanks for any help. Tom
Joined: 12/27/2012(UTC) Posts: 5,521  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
a cut between clips IS a transition ;-)
you want to have an actual recorded single file or a playback of all with another type of transition?
Joined: 7/24/2018(UTC) Posts: 96 Location: Carrollton, GA
Thanks: 1 times Was thanked: 15 time(s) in 11 post(s)
Here is how I do this.
At the end of the night, I prepare a "Melt" which is a list of the good highlights I want to keep.
I check the angles I want and I highlight them all and make sure my transition in the event settings is set to fade. I also make sure my audio playback is what I want.
I then put A or B in Program and Hit Record then and render them (Mp4) out that way with Fades. Traditionally though, a post-show melt would have cuts and not fades since that makes it easier for others to edit. Really just a matter of preference though.
Just another way of doing it. Hope this helps.
 1 user thanked Radiotvpat1982 for this useful post.
Instant Replay
