hypnophone
#1 Posted : Wednesday, January 27, 2021 10:40:35 AM(UTC)
hypnophone
I want to change sources for outputs 3 and 4 with a shortcut so I can change return video to vMix callers without going into the settings menu. For some reason, I can't figure out how these shortcuts work. In the shortcut SetOutput3 I enter the parameter input and select input 1 from the pull down, but when I observe the output, pressing the midi button makes no change of state. Anybody know what I am missing in this?
SportsNetUSA.net
#2 Posted : Saturday, January 30, 2021 11:44:25 AM(UTC)
SportsNetUSA.net
The Output won't change while you have the Outputs/NDI/SRT window open. Set Output 3 to Output. Close the window. Then press your Shortcut button. Go back to Outputs/NDI/SRT to see the change to Input 1.
