h2video.nl
#1 Posted : Monday, August 11, 2014 4:24:11 AM(UTC)
h2video.nl
hi Martin,
as mentioned in the other audio discussion it would be nice if vmix 14 could include a quality setting for audio recording. the setting would set the bitrate of the recording, p.e. 320 kbps or higher, if desired.
in addition it would be nice to be able to record multichannel, so different inputs can be recorded with the video. for playback later you can choose what channels to use or mix it down.
lastly, it would be nice to be able to select what audio channels will be output to external, so recording is different from the livestream ( as can be done with overlays...) and to be able to select one channel (mono) and output it as dual mono left / right in the stream.
this way all options are available during recording and streaming and productions can be changed in post processing, per example if you publish a recording on youtube.
greetings,
stefan
