Question to Martin - API calls and Storyboard functionality
Hi Martin, As stated many times before - thank you for a great product, that is extermly flexsible and fun to work with.
#1: We have develop a number of XAML overlays for showing scores etc. The TEXT fields are being fill out by a seperate program by making HTTP commands as described in the API documentation. In some of our XAML files there are more than 25 fields that needs to be set before showing the result screen.
QUESTION: Is there a way to set more than one TEXT field per HTTP command/call ?
We would like to make just ONE call to the vmix api instead of 25.
#2: On our XAML files we use StoryBoard1 and StoryBoard2 for making in and out animations. This works like a charm. Is it possible to have a third storyboard (StoryBoard3) that fx. repeats itself while its active on the output and waiting for the OUT transition ??
This feature is on our wishlist if it's not possible today.
Best regards Ulrik
As far as im aware there is no way to change multiple fields in one request.
For ours, we have 8 fields to change and the time delay isn't noticeable to viewers. However, for 25 it might be so what you can do is use the shortcut in the API called PauseRenderer which will pause the updating of inputs, then ResumeRenderer when done. That wiay they will all change at once.
