vMix Headphone Audio issues with v23.0.0.67x64
Joined: 8/5/2020(UTC) Posts: 10  Location: Fort Worth Was thanked: 1 time(s) in 1 post(s)
Ever since I did the last update v23.0.0.67x64 I am no longer able to get an output for the headphones, only the master output. Before this update I was able to have simultaneous audio outputs, now I am unable to make the headphone output work at all. I am using my same preset as before the update, nothing else changed. This has been verified on multiple identical systems.
I am on Windows 10 Pro, OS build 19041.685. The system is an i9-9900k CPU@3.6GHz, 16GB, NVIDIA GeForce RTX 2070 Super.
I am going to uninstall this version and go back to the previous version to see if that restores the functionality.
Has anyone else encountered this challenge?
I can confirm that uninstalling v23.0.0.67x64 and installing the previous version v23.0.0.66x64 fixes the issue.
There is something not working as expected with the latest update. Please install with caution and check your systems before deploying to your studios.
