Camera IP TRENDNET TV IP 410WN
Hello. ( I'm french and use an automatic translation )
I try to capture the flow of a TV camera IP TRENDNET IP410WN, unsuccessfully.
I go the address into RTSP over UDP: rtsp: // 192.168.1.240 / admin / view.cgi? Profile=2
He(It) gives me the error: no connection was able to be established because the target computer expressly refused her(it) 192.168.1.240:554
If I bring in: in RTSP over UDP: rtsp: // 192.168.1.240:80 / admin / view.cgi? Profile=2, he(it) gives me the error: impossible to read the data of the connection of transport: an attempt of connection failed because the connected party did not answer suitably beyond certain duration or an established connection failed because the host of connection did not answer.
I tried other manners, but unsuccessfully.
Have you a solution?
Thank you in advance
Thanks: 1 times Was thanked: 7 time(s) in 7 post(s)
I have seen the same error when the RTSP port of the IP camera is set to something other than 554 On the camera, change the RTSP port to 554 or specify the port in your connection stream of vMix example, if RTSP port on camera is 7000 rtsp://x.x.x.x:7000/<options> HOWEVER.... if you look at THIS link it says the RTSP connection string could be one of those shown below rtsp://IPADDRESS:554/play1.sdp rtsp://IPADDRESS:554/play2.sdp rtsp://IPADDRESS:554/play3.sdp Try one of those connection strings and see if that works
