smokinzx6r
#1 Posted : Wednesday, January 6, 2021 5:18:43 AM(UTC)
smokinzx6r
Canada
Added a ticker as overlay 4. Overlay 4 has a trigger to delay it 5 seconds. Ticker comes on as designed, however more than a sentence has already scrolled past before the trigger makes it show up.
How do I get it to delay the text until the ticker becomes active?
Barry
#2 Posted : Wednesday, January 6, 2021 8:35:52 AM(UTC)
if i understand correctly you have a trigger on the input you overlay on itself to delay it ?
smokinzx6r
#3 Posted : Wednesday, January 6, 2021 8:55:08 AM(UTC)
smokinzx6r
Canada
Yes that's right.
#4 Posted : Wednesday, January 6, 2021 9:30:09 AM(UTC)
Originally Posted by: smokinzx6r Go to Quoted Post
Yes that's right.
How did you do that ? and your logic ?
smokinzx6r
#5 Posted : Wednesday, January 6, 2021 9:36:39 AM(UTC)
smokinzx6r
Canada
I just set the overlay to appear after 6 seconds.
The pastor announces what the scripture is and an overlay appears with the scripture on it. Then the ticker appears at the bottom and scrolls the text.
Can't have the text scroll until about 6 seconds in.
#6 Posted : Wednesday, January 6, 2021 10:33:05 AM(UTC)
Oh, the scripture overlay triggers the ticker overlay to appear after 6 seconds , makes more sense now.
Check on the ticker to auto restart with transition
