vMix Call
No Audio Meters for vMix calls
Joined: 9/7/2020(UTC) Posts: 13  Location: Louisville Thanks: 5 times
No meters in the mixer display for the (8) vMix Call channels.
Other types of audio inputs seem to work normally.
Click on audio settings for any Vmix Call channel and you only see PRE meters moving and no POST. the PRE meters that you do see in the audio settings are greyed-out but are moving as you speak into the mic.
the audio is working and can be routed to the various busses, even though there are no meters in the mixer display.
I've also found that the audio SOLO on vMix Calls does not work. I can send that audio to a BUS, and solo it from the BUS, but not the channel.
The only way I have meters at all is to click on the set-up gear in the audio channel. There I can see the display that shows me a PRE only audio meter.
I can't use any of the audio tools etc..
Joined: 10/31/2020(UTC) Posts: 205  Thanks: 6 times Was thanked: 46 time(s) in 45 post(s)
There must be something weird in your configuration, because I just tested it, and all the audio tools work. I see the pre and post meters going up and down just like all the other inputs. I enabled the compressor, and slid the ratio all the way up, and the threshold all the way down, and it was definitely working. The pre meter showed the normal activity, and the post meter showed almost no activity, because the compressor was in full force. I didn't try VST or EQ.
FWIW, I'm using vMix Pro v24.0.0.50
Thanks - I will double check all my configuration settings.. I'm also using the latest 24.0.0.50
Just to be clear, this only happens on vMix calls. Other inputs (audio mixer, video rolls, etc) work fine.
I'll post in a couple of days if I had any luck.
Yes, vMix Call.
However, I think solo might not be working. I hit the "S" on one of the other inputs, but the vMix Call audio was still going through to Master. I don't think that's supposed to happen.
 1 user thanked kross for this useful post.
In a normal audio mixer, your solo would (mostly) be used simply for your monitor/headset (also sometimes metering).
It shouldn't affect the routing of a signal to wherever it's going and you should be able to listen to multiple solo'd channels simultaneously.
I'm still looking for some kind of setting that speaks to the solo buttons/system but no luck so far.
I'm still having the same issues 3 years later after multiple upgrades. Using the latest version now.
vMix Call
