Joined: 1/2/2021(UTC) Posts: 2  Location: North Carolina
I occasionally use simple animated GIF files in my productions. These may show, for example, mist drifting across a forest floor. They used to run/loop very smoothly, but now the speed seems to vary. It makes the animation slow down and then speed up which completely destroys the effect. Any changes to vMix that would cause this?
Joined: 7/28/2019(UTC) Posts: 351  Location: Santa Rosa Thanks: 1 times Was thanked: 53 time(s) in 51 post(s)
Can you convert them to a PNG or Tiff sequences? That should work more reliably. It also works with GT.
I could do that. I was just wondering why they used to work fine, and now they don't.
