Hall3008
#1 Posted : Friday, January 1, 2021 5:59:44 AM(UTC)
Hall3008
Croatia
I'm not sure if this is a bug or you didn't anticipate people going this far. Or you wanted it to be like this. Namely, as you can see in the picture. This is an example of how you can easily get a view of this bug.
Put one image and load that image into color input Color1 on multyview on no1. position. Then load the input Color2 and on the multyview set to the position no1 Color1. So far, everything is working properly. But now if you create a Color3 input and put a Color2 in it, you don't get an image. I'm not sure if it's a bug or it has to be. I've made a lot of great inputs and this is a real problem because it doesn't work. Is that to be corrected or?
This is abbreviated:
slika1> Color1 (with slika1)> Color2 (with Color1)> Color3 (with Color2)
I hope you manage to solve the problem.
Look:
#2 Posted : Friday, January 1, 2021 8:31:08 AM(UTC)
Not a bug but a feature'
vMix is limited to stacking multiviews 2 deep for performance reasons (a simple search would have given the same answer)
