Hardware Compatibility
BlackMagic Quad HDMI Capture Device Issues
Joined: 12/30/2020(UTC) Posts: 2  Location: O Fallon Missouri
About 5 months ago we switched our capture device to the BlackMagic Quad HDMI capture device to be able to have multiple cameras in our recordings. Ever since then we have had constant issues with our image clarity. I have made sure to match all vmix settings with the settings that the capture device is putting out and made sure to have the high performance turned on within vMix. If anyone has had similar issues or could shed some light on what the issue could be would be much appreciated.
High Input Performance Mode?
If you plan on using a large number of cameras (typically > 8) and a large number of inputs, performance can be improved by ticking this checkbox. Note that this only works on graphics cards with a large amount of built in memory (3GB+) and will result in poor performance if enabled on graphics cards with less memory, or Intel graphics.
Hey Elvis thanks for the reply. I already have high performance mode enabled in vMix and our graphics card can definitely handle it. Is there anything else that you can think of that could be causing the clarity issues?
