livestreaming
#1 Posted : Friday, December 18, 2020 2:03:13 PM(UTC)
livestreaming
Hello you all!
It would be nice that the API would reflect the streaming status whenever any issue occurs.
As the GUI button turns yellow to warn that streaming is not running smoothly, i could only find the ACTS TCP API to remain do value "1" as for streaming active instead of changing to something else.
XML response on the web end also returned as if the stream was normal.
I am implementing those status on external tally lights and it would be a great deal to have external visual warning that there are issues while streaming as the GUI button can be too small to notice when you are focusing on the multiviewer.
Thanks guys!
