r1nk
#1 Posted : Wednesday, December 16, 2020 7:22:07 PM(UTC)
r1nk
Malaysia
Basically from what I can see, vMix Virtual Sets only have Zoom In/Zoom Out option.
What if I want to create virtual camera movement? See example below :-
[img]https://ibb.co/D9QZFXk[/img]
[img]https://ibb.co/WnQ8jZh[/img]
[img]https://ibb.co/6gFZdxr[/img]
It is not possible to use vMix only to achieve this right? Do you guys have any virtual studio software in mind that can integrate with vMix to achieve those results in the images?
Or if can totally use vMix only, care to clarify how I can achieve it?
#2 Posted : Wednesday, December 16, 2020 7:52:05 PM(UTC)
For something like this, I would use Unreal Engine
Vince Beck
#3 Posted : Thursday, December 17, 2020 6:15:49 AM(UTC)
Vince Beck
Also look at VSet 3D http://www.vset3d.com/?v=11aedd0e4327 It gives you similar capabilities but it's more suited for live.
r1nk
#4 Posted : Monday, December 21, 2020 5:05:09 PM(UTC)
r1nk
Malaysia
Yeah, from my research, seems like this is the only external software that can achieve same as the examples I gave. OK, thanks.
r1nk
#5 Posted : Monday, December 21, 2020 5:31:01 PM(UTC)
r1nk
Malaysia
Meaning, all controls coming from Unreal Engine? But then how can from Unreal Engine send to the vMix?
#6 Posted : Monday, December 21, 2020 7:14:49 PM(UTC)
Unreal has plugins to ingest live SDI, HDMI or NDI feeds
Unreal also has plugins to output SDI, HDMI and NDI feeds
PFBM on 1/29/2021(UTC)
Eric Marodon
#7 Posted : Thursday, December 24, 2020 1:49:10 AM(UTC)
Eric Marodon
For a semi-affordable professional solution you can also check aximmetry DE:
https://aximmetry.com/en/products
There's a free version, but you need the paid version if you want more outputs and NDI.
thanks 1 user thanked Eric Marodon for this useful post.
Guest (6)
