Joined: 10/27/2020(UTC) Posts: 3  Location: Mississauga
 Examplevmix.jpg (472kb) downloaded 1 time(s).I find when I have an image as an input, usually a custom lower third. It looks soft as soon as I put it into Vmix. It looks even worse when I scale down to fit a pip. Is there a fix or a work around for this issue in vmix. I've used other systems with no issues with the same files ( Barco E2 ). Running Vmix HD 23.0.0.65 x64...also tried on the 4k vmix machines same issue. Thank You
 beforevmix.jpg (182kb) downloaded 0 time(s). here is the same image before it gets into vmix
