Martin Block
#1 Posted : Monday, December 7, 2020 9:19:37 AM(UTC)
Martin Block
Philippines
I like using the InputPreviewNext trigger a lot to move through a show just using my spacebar or Streamdeck to transition to the next cue.
However, lot of times I have various inputs like name overlays, VO files, songs, etc next to my “main inputs” that are associated with these.
So in order to use InputPreviewNext, I need to move these files to the bottom of the inputs. Which makes it hard to find these files for last minute changes etc.
It would be great to be able to place all my “main inputs” in a category tab and then have a shortcut/trigger: InputPreviewNextSameCategory
This way,I could just have a category for all my main show files and transition easily from one to the next within that category.
Please +1 if you also would like this feature
blackburst
#2 Posted : Saturday, January 29, 2022 7:19:05 AM(UTC)
blackburst
+1 even if it was just the same shortcut, but made contextual to what category you're currently in.
