LG
#1 Posted : Sunday, August 3, 2014 12:17:24 PM(UTC)
LG
powerpoint slided per slide time setting so that when you open up the slide settings window you can not only set a dureation for al the slided buth click a slide and then give its own duration
for those slides that did not get a private duration settins are based on the general duration setting.
