Joined: 10/21/2020(UTC) Posts: 17  Location: Bulkington Thanks: 5 times
I'm trying to work out how to implement a variable array in vMix Nothing too complex, I just want to fill in some text boxes, but rather than so 100 variables, i wanted to create a single array and have it run through adding 1 and updating the text, as well as learn and understanding arrays, for future scripting! below is a VERY basic test of an array Dim arr as string()
arr(0) = "xxx"
Console.WriteLine (arr(0))
however although it saves correct (so the syntax is right), it produces an error! For some reason, I just can't quite get it, so any help would be apricated.
