Joined: 11/20/2020(UTC) Posts: 74   Thanks: 13 times Was thanked: 9 time(s) in 9 post(s)
Hi Folks,
after quite a couple of shows each with several caller I came to (for me working best) the solution:
General set Up: -Studio with cameras -Moderator plus very few participants live on stage -Callers as external participants -Audio System (Mics etc) -Video Mixing desk separate -Vmix PC with HD SDI input Cards -external Sound Out via USB -Inputs 1-4 ALWAYS Call 1-4 -Inputs 5&6 ALWAYS Input from Audio Desk/Headset Mic
Audio Buses: all M-G Audio Sources Call 1 D Call 2 E ...
Bus B&C for collecting calls (if needed) for routing to Master together
Headset on A
multiple Buttons for Stream Deck (or what ever)
Scripting 1. Talk Back Call1 API.Function("AudioBusON", Input:=1, Value:="A") API.Function("AudioBusON", Input:=6, Value:="D") API.Function("AudioBusOFF", Input:=1, Value:="M") API.Function("AudioON", Input:=1) ´just for safety API.Function("AudioON", Input:=6)´just for safety
2. Talk Back Call 2 API.Function("AudioBusON", Input:=2, Value:="A") API.Function("AudioBusON", Input:=6, Value:="E") API.Function("AudioBusOFF", Input:=2, Value:="M") API.Function("AudioON", Input:=2) ´just for safety API.Function("AudioON", Input:=6)´just for safety
aso...
3. Show Call 1 API.Function("AudioBusON", Input:=1, Value:="M") API.Function("AudioBusON", Input:=5, Value:="D") API.Function("AudioBusOFF", Input:=1, Value:="A")
and so on
This way it works real fine and is easy to use!
aaahhhh... get the Scripts to the Stream Deck Buttons :-)
Joined: 11/24/2020(UTC) Posts: 10  Location: Chamigny Thanks: 7 times Was thanked: 3 time(s) in 3 post(s)
Thanks, Chris...
We must test this soon. it's very nice to have shared this!
Joined: 3/20/2014(UTC) Posts: 2,721   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
There are several ways to get there yes... With DynamicInputs in v24, it's now possible to simplify all this... Less shortcuts/scripts required
If you want more flexibility regarding inputs position, use GUIDs, rather than input numbers, in your local scripts
