Dave L
#1 Posted : Saturday, November 28, 2020 1:19:49 PM(UTC)
Dave L
Hi, I am a new VMix user. I am using a PC system. My 2013 Intensity Pro Capture card image is not showing up when I try and add the cameras. VMix 23.0.0.66 sees the cameras in the drop down menu but none of the settings I try have made the camera's appear. My Intensity Pro cameras are showing up perfectly in my Wirecast software so I know the problem is not with the cameras, capture cards or my computer. My Intensity Pro Card input settings show:
Input: HDMI 720p59.94
Output: Component 1080p 29.97
I tried several combinations but I could not get it to work.
Can someone let me know:
1. Is the 2013 Intensity Pro is compatible with VMix 23?
2. If it is, what settings are do you recommend to make the cameras appear?
Any help would be greatly appreciated. Thanks!!
Dave
ljudatervinning
#2 Posted : Thursday, December 10, 2020 6:40:07 PM(UTC)
ljudatervinning
Sweden
I am new to vmix, but have an older Intensity pro card working in vMix 23. Once I entered the exact picture settings, all worked as expected.
