Minklemoo
#1 Posted : Thursday, November 12, 2020 1:06:21 AM(UTC)
Minklemoo
I'm doing 4 vmix calls, routed to outputs, and multicordering them to fault tolerant mp4 files.
Each file going to a different folder (ISO1, ISO2 etc)
One thing I've noticed is that vmix isnt writing an xml file in each folder for each file. Is that correct?
So when I run the file through vmix tools to create an mp4 file that avid media composer likes, should I copy that xml file from ISO 1 folder to the others?
