samirbridi
#1 Posted : Wednesday, November 11, 2020 2:25:54 PM(UTC)
samirbridi
Brazil
For days I have been testing a communication via NDI between two VMix. What is sending the videos and titles, runs perfectly, however in VMix that receives the signal to use and stream, it presents some problems. Why is this happening? Is there any configuration to be done in the VMDI NDI so that both machines work in sync, without having these crashes?
Both machines have a dedicated GPU.
Stream machine (receives signal when locking sometimes) - GTX 1660ti 6GB
Videos / titles machine (only sends signal via NDI) - AMD RADEON HD6570 8GB
I'm using a TL2500G-10TS manageable switch.
Network cables are Cat6.
Maximum data flow when analyzing by the Windows manager, 200mb.
Note: I noticed that there is a configuration in VMix where it says "Vmix NDI Config". I did a test marking the options correctly, and even then, it didn't work.
I hope you can help me in this case and identify the problem with this crash.
Thanks!
