jguk
#1 Posted : Thursday, November 5, 2020 6:33:26 AM(UTC)
jguk
Hi Guys,
A strange one for you - and not something I've noticed before, it could well be that it's always been like that, but I don't have any other systems to test.
Basically if I open vMix with 0 inputs, then resizing and moving the vMix window works exactly as you would imagine.
Once I get to around 20-30 inputs open - when I drag the vMix window around the screen, the movement appears to be super sluggish and can sometimes take a few moments to catch up to my mouse. Doesn't seem to matter what I have in the inputs, even 30 x PNG or JPG images and still the issue persists.
GPU and CPU percentages are all sub 30% when moving the window - even task manager in windows reports fairly low usage.
GPU is GTX1080
CPU is i7-6700k
RAM is 32GB
Would you guys be able to tell me if this is a common thing ?
jguk
#2 Posted : Tuesday, November 10, 2020 4:22:06 AM(UTC)
jguk
So I've done some more investigation and managed to figure out what was causing this.
I've got a Zowie FK1 mouse - and it seems to be a bug caused by the USB report rate set too high. If anyone else is struggling with weird performance issues whilst using a gaming mouse and trying to move the vMix window on screen, try changing your USB report rate on the mouse to 125hz !!
Hope this helps someone !
