DBC-Stream
#1 Posted : Monday, November 2, 2020 2:41:11 AM(UTC)
DBC-Stream
Good day, I've been running vMix for my church's livestream since we installed it in July. Recently, I've started having issues when I load the saved vMix file for the stream. Particularly, the Audio input will show as "offline". This doesn't happen every week but it seems to be occurring with increased frequency lately. Generally, if I reset the computer the issue seems to fix itself but today I had to reset the computer nearly 10 times before the audio began to work again. Has anyone else ran into this issue?
SportsNetUSA.net
#2 Posted : Monday, November 2, 2020 4:05:03 AM(UTC)
SportsNetUSA.net
So you don't have to "reset" the computer, click on the Cog on the Audio Input, click Change, then select the audio device again from the drop down menu.
thanks 1 user thanked SportsNetUSA.net for this useful post.
DBC-Stream on 11/2/2020(UTC)
DBC-Stream
#3 Posted : Monday, November 2, 2020 6:39:42 AM(UTC)
DBC-Stream
So basically just rechoose the same audio input I’m already using to reconnect?
SportsNetUSA.net
#4 Posted : Monday, November 2, 2020 10:31:25 AM(UTC)
SportsNetUSA.net
Yes. I just loaded a Preset that has a Microsoft LifeCam as an input. It comes up "Offline". To get it online, it's Gear Icon, etc.
Guest (4)
