Joined: 10/30/2020(UTC) Posts: 4  Location: Sao Paulo
Hello everyone. I have noticed that the performance of the dedicated graphics card has not performed well. I did tests between the onboard and the dedicated Nvidea gtx 1060, and the difference is only 5% GPU and CPU. I have also noticed that the Vmix software has been "heavier". It seems that it doesn't "flow" as lightly as it used to. Have there been any major changes to the software that justify this loss of performance?
I understand. But a mean, dedicated GPU (as nVidia) should be far more powerfull than the integrated GPU. Maybe the vMix now is only optimized for nVidia RTX cards... Because on my GTx 1060, i haven't much difference between them. The difference between dedicated (GTX 1060) and onboard (INTEL) it's just 5%.
