tvfabrik
#1 Posted : Thursday, October 29, 2020 5:23:41 AM(UTC)
tvfabrik
Germany
Hi Folks!
I would like to have stream-startscreen with an countdown (no problem with the countdown - i do it with Fusion)
This mp4 file is counting in the background.
In a small window (in front) i want to show the live-stream from my atem mini.
If the countdown is finished i want to show the live-stream in full-stream.
And this changing (from small to Full Screen) i want to animate/zoom to fullscreen.
My workflow is:
Input01 from Atem mini
Input02 virtual input from Input01
Input03 is the mp4 with the countdown
changing the size in "Input02/Settings/Position"
and now it works if set Input01 in Preview and Input02 ist live at PGM and by pressing "Merge" it zooms to fullscreen - PERFECT!
But how will i get the countdown MP4 in the background?
Thanks in advance - and sorry for my english ;-)
dmwkr
#2 Posted : Saturday, October 31, 2020 6:32:17 PM(UTC)
dmwkr
Do it the other way around: You can't add a background, but Multiview Layers as overlays to inputs.
https://www.vmix.com/hel...utSettingsMultiView.html
