I'm making a recording of some screens created for a 1080p resolution with placeholder gaps for video overlays. Is there any way of specifying exact pixel x/y positions (like 100, 100 for example) when positioning the video overlays?
I get that the relative positions scale to all resolutions but this is driving me cracked because I can't position the videos to match the pre-designed backgrounds without tiny gaps, etc. In OSB (don't judge me :-) ) you can specify exact pixel positions, which is incredibly helpful in my context!
Thanks for any advice or help.
Rickard.
@ PureCorkBoy
Not pixel perfect, but you can fine tune the sliders by mousing over and using the scroll wheel.
Thanks for the tip. In the end I just worked out the math to convert the pixels into relative positions. Annoying but easy enough. 😀
