offsourcetech
#1 Posted : Wednesday, October 21, 2020 7:57:40 AM(UTC)
offsourcetech
I've been using Vmix pro for several months, but this is a new problem.
I've got a Blue Yeti USB mic and it's recently started clipping in the recordings and streams. The issue started about a month ago, without changing any of the settings on the mic or in Vmix. I've since tried adjusting at every stage of the signal, but no fix has been found.
Whether I turn down the gain on the mic, turn down the device volume, or turn down the volume at the mixer level in Vmix, I still get the clipping, it's just a quieter signal overall. I've tested the hardware in other applications like Adobe Audition and Audacity and the problem doesn't occur there. In my tests, I'm using the same settings (48000, 32 bit floating, 2 channel).
This issue isn't occurring with any of my callers, many of whom are using the same mic as myself.
Audio engineering is not my strong suit, so I'd appreciate any suggestions in diagnosing the issue.
Is there any chance that a recent update has changed something I need to compensate for?
