Feature Requests
VMIX Call staus updated in the API
Joined: 3/25/2020(UTC) Posts: 48  Location: Chichester Was thanked: 10 time(s) in 7 post(s)
There is also another request on VMIX Call status to be shown However this one is for adding the call staus to the XML API / Web api call.
I have been looking at how to identify if a Vmixcall caller is connected and live or disconnected. The API XML only shows STATE as "Running" from creating the video call.
<input key="5a0d0e85-bddd-4279-bd7c-3925a7e52b51" number="2" type="VideoCall" title="Call 5512658121" shortTitle="Call 5512658121" state="Running" position="0" duration="0" loop="False" muted="False" volume="100" balance="0" solo="False" audiobusses="M,B" meterF1="0" meterF2="0">Call 5512658121</input>
I can see from the Videocall logs (Advance setting) when setting up connection details when a call is made and disconnected. The connecion details are available also when you open the call manager as it shows green/amber when the call is established and red when disconnected (however bad internet may be also red)
What would be great is that the State in the XML or additional parameter actually shows the caller connection state. I sure it could be something simple to add and prove to be very valuable for many applications especially when controlling multiple guest callers in a queue system....
+1
Feature Requests
