2 Pages<12
Ittaidv
#21 Posted : Wednesday, January 21, 2015 9:38:09 AM(UTC)
Ittaidv
We have had exactly the same problem during a few of our past gigs. We use the most up to date version of VMix.
These are some of the log files:
17/01/2015 21:17:30, Version: 14.0.0.112 x64
17/01/2015 21:17:30, Size: 1280x720
17/01/2015 21:17:30, System: PAL 50i
17/01/2015 21:17:30, Codec: Microsoft MPEG-2 Encoder
17/01/2015 21:17:30, Format: UYVY 16 1498831189
17/01/2015 21:17:30, AudioDevice: vMix Audio
17/01/2015 21:17:30, AudioFormat: 44100 Hz 16 Bit 2 Channels
17/01/2015 21:17:30, AudioDelay: 0
17/01/2015 21:17:30, RestartInterval: 0
17/01/2015 21:17:30, Buffers: 50
17/01/2015 21:17:30, BitRate: 12
17/01/2015 21:17:31, StartRecording
17/01/2015 21:24:39, StopRecording
17/01/2015 21:24:39, Duration: 00:07:07
17/01/2015 21:24:39, Frames: 10679
17/01/2015 21:24:39, DroppedFrames: 0
17/01/2015 21:24:39, DueToSourceFrameRate: 0
17/01/2015 21:24:39, DueToHardDiskOrCPU: 0
17/01/2015 21:24:39, DroppedSamples: 0
17/01/2015 21:24:39, MissedSamples: 0
17/01/2015 21:24:39, SyncedSamples: 0
17/01/2015 21:24:39, AudioOffset: 20
17/01/2015 21:24:39, AudioDelay: 0
17/01/2015 21:24:39, AudioEngine
17/01/2015 21:24:39, Running: True
17/01/2015 21:24:39, SampleRate: 44100hz 16 Bit
17/01/2015 21:24:39, MixingErrors: 0
17/01/2015 21:24:39, Streams
17/01/2015 21:24:39, Mixer
17/01/2015 21:24:39, Samples: 26188
17/01/2015 21:24:39, Dropped: Read 0 Write 0
17/01/2015 21:24:39, Latency: 0 ms
17/01/2015 21:24:39, Errors: 0
17/01/2015 21:24:39, Headphones
17/01/2015 21:24:39, Latency: 10 ms
17/01/2015 21:13:57, Version: 14.0.0.112 x64
17/01/2015 21:13:57, Size: 1280x720
17/01/2015 21:13:57, System: PAL 50i
17/01/2015 21:13:57, Codec: Microsoft MPEG-2 Encoder
17/01/2015 21:13:57, Format: UYVY 16 1498831189
17/01/2015 21:13:57, AudioDevice: vMix Audio
17/01/2015 21:13:57, AudioFormat: 44100 Hz 16 Bit 2 Channels
17/01/2015 21:13:57, AudioDelay: 0
17/01/2015 21:13:57, RestartInterval: 0
17/01/2015 21:13:57, Buffers: 50
17/01/2015 21:13:57, BitRate: 12
17/01/2015 21:13:59, StartRecording
17/01/2015 21:15:54, StopRecording
17/01/2015 21:15:54, Duration: 00:01:55
17/01/2015 21:15:54, Frames: 2884
17/01/2015 21:15:54, DroppedFrames: 0
17/01/2015 21:15:54, DueToSourceFrameRate: 0
17/01/2015 21:15:54, DueToHardDiskOrCPU: 0
17/01/2015 21:15:54, DroppedSamples: 0
17/01/2015 21:15:54, MissedSamples: 0
17/01/2015 21:15:54, SyncedSamples: 0
17/01/2015 21:15:54, AudioOffset: 0
17/01/2015 21:15:54, AudioDelay: 0
17/01/2015 21:15:54, AudioEngine
17/01/2015 21:15:54, Running: True
17/01/2015 21:15:54, SampleRate: 44100hz 16 Bit
17/01/2015 21:15:54, MixingErrors: 0
17/01/2015 21:15:54, Streams
17/01/2015 21:15:54, Mixer
17/01/2015 21:15:54, Samples: 11591
17/01/2015 21:15:54, Dropped: Read 0 Write 0
17/01/2015 21:15:54, Latency: 0 ms
17/01/2015 21:15:54, Errors: 0
17/01/2015 21:15:54, Headphones
17/01/2015 21:15:54, Latency: 20 ms
17/01/2015 22:09:28, Version: 14.0.0.112 x64
17/01/2015 22:09:28, Size: 1920x1080
17/01/2015 22:09:28, System: PAL 50i
17/01/2015 22:09:28, Codec: Microsoft MPEG-2 Encoder
17/01/2015 22:09:28, Format: UYVY 16 1498831189
17/01/2015 22:09:28, AudioDevice: vMix Audio
17/01/2015 22:09:28, AudioFormat: 44100 Hz 16 Bit 2 Channels
17/01/2015 22:09:28, AudioDelay: 0
17/01/2015 22:09:28, RestartInterval: 0
17/01/2015 22:09:28, Buffers: 50
17/01/2015 22:09:28, BitRate: 12
17/01/2015 22:09:31, StartRecording
17/01/2015 22:11:56, StopRecording
17/01/2015 22:11:56, Duration: 00:02:25
17/01/2015 22:11:56, Frames: 3318
17/01/2015 22:11:56, DroppedFrames: 252
17/01/2015 22:11:56, DueToSourceFrameRate: 0
17/01/2015 22:11:56, DueToHardDiskOrCPU: 252
17/01/2015 22:11:56, DroppedSamples: 0
17/01/2015 22:11:56, MissedSamples: 0
17/01/2015 22:11:56, SyncedSamples: 0
17/01/2015 22:11:56, AudioOffset: 0
17/01/2015 22:11:56, AudioDelay: 0
17/01/2015 22:11:56, AudioEngine
17/01/2015 22:11:56, Running: True
17/01/2015 22:11:56, SampleRate: 44100hz 16 Bit
17/01/2015 22:11:56, MixingErrors: 0
17/01/2015 22:11:56, Streams
17/01/2015 22:11:56, Mixer
17/01/2015 22:11:56, Samples: 127328
17/01/2015 22:11:56, Dropped: Read 0 Write 0
17/01/2015 22:11:56, Latency: 0 ms
17/01/2015 22:11:56, Errors: 0
17/01/2015 22:11:56, Headphones
17/01/2015 22:11:56, Latency: 50 ms
17/01/2015 22:11:56, AV
17/01/2015 22:11:56, Samples: 127082
17/01/2015 22:11:56, Dropped: Read 257 Write 0
17/01/2015 22:11:56, Latency: 100 ms
17/01/2015 22:11:56, TargetLatency: 80 ms
17/01/2015 22:11:56, Resampled: 5120/120
17/01/2015 22:11:56, Samples: 127054
17/01/2015 22:11:56, Dropped: Read 236 Write 0
17/01/2015 22:11:56, Latency: 80 ms
17/01/2015 22:11:56, Resampled: 4680/180
17/01/2015 22:11:56, Samples: 127048
17/01/2015 22:11:56, Dropped: Read 472 Write 0
17/01/2015 22:11:56, Latency: 60 ms
17/01/2015 22:11:56, Resampled: 9420/140
17/01/2015 22:11:56, Samples: 127042
17/01/2015 22:11:56, Dropped: Read 365 Write 0
17/01/2015 22:11:56, Resampled: 7260/160
17/01/2015 22:11:56, DirectShow
17/01/2015 22:11:56, Samples: 127033
17/01/2015 22:11:56, Dropped: Read 4 Write 0
17/01/2015 22:11:56, Resampled: 0/60
17/01/2015 22:11:56, FFMpeg
17/01/2015 22:11:56, Samples: 2733
17/01/2015 22:11:56, Dropped: Read 1 Write 0
We solved it by running FMLE seperate from Vmix and by switching from a SSD to a normal harddisk and not using the ts but the Mpeg codec. From then on everything ran smooth.
We always have this while recording shows that are using a complex light setup (fast lights), combined by a slightly unstable internet connection.
No idea what is actually causing this problem in our case, but we sometimes faced this problem several times in a few minutes.
Since our streaming is not as important as our recordings, we really would love to see this problem solved.
#22 Posted : Wednesday, January 21, 2015 11:09:32 AM(UTC)
Was thanked: 4733 time(s) in 1623 post(s)
12 Mbps is a bit too small for reliable MPEG-2 recording at 720 and 1080 resolutions.
Try at least 25 Mbps and you should see much better results.
Also the 50i frame rate in the first log file seems incorrect for 1280x720, perhaps it should be 25p instead?
2 Pages<12
