I'm so happy with this rack mount case that I'm posting here too
Joined: 7/28/2019(UTC) Posts: 351  Location: Santa Rosa Thanks: 1 times Was thanked: 53 time(s) in 51 post(s)
Perfect for the Obsidian system. https://www.silverstonet....php?pid=921&area=eneATX compatible, accommodates the 240mm Water CPU cooler in the front grill and actually usable modern ports on the front panel. Best of all, it's the only eATX case I've found to fit in a standard 20" deep rolling rack. Just built my first system with this one and it's a dream.
Thanks: 4 times Was thanked: 20 time(s) in 19 post(s)
good to hear.. i have been keeping an eye out with rack case as i might need something down the line.. do you think it would be able to use larger CPU air coolers also ? I looked at 4RU measurements in the past and it looks like that size should be able to hold coolers like a noctua but hard to know without a mobo is installed..
I’m not sure how well the air cooler would work with little room on top. I find that the water cooler work very well in this case with the 10 core i9.
