jaredquinn
#1 Posted : Wednesday, October 7, 2020 11:31:12 PM(UTC)
jaredquinn
My audio interface brings in channels as stero pairs; when separating those channels there does not appear to be a way to send the second channel (2) volume to an activator.
Volume is being set with
SetVolumeChannel1
SetVolumeChannel2
Please add an InputVolumeChannel1/2 activator.
mavik
#2 Posted : Thursday, October 8, 2020 12:23:15 AM(UTC)
mavik
You can use the Channel Matrix to select which audio is routed to what channel. You could route the left and right channel differently and use a Bus for example.
polsten
#3 Posted : Thursday, October 8, 2020 8:10:54 AM(UTC)
polsten
Germany
Hey,
what Audio-Interface do you use?
Not sure if this is your Problem, but did you install the ASIO drivers for your Device?
with ASIO drivers for my Focusrite and my Steinberg interfaces I can choose which AudioInterface Input I want do set as an Input in vMix.
But look when you create an AudioInput in vMix... i.E. take "Focusrite ASIO USB" and not "Focusrite USB"....
jaredquinn
#4 Posted : Thursday, October 8, 2020 7:32:03 PM(UTC)
jaredquinn
Originally Posted by: polsten Go to Quoted Post
Hey,
Please re-read my post. Everything is working except the activator to show separate levels on my midi controller.
There's shortcut functions for inputvolumechannelX but there is only a single input volume activator event.
Jared
myoung
#5 Posted : Wednesday, April 9, 2025 1:05:37 PM(UTC)
myoung
+1
