NDI
Bind NDI to one NIC
My NDI server has multiple network cards. The idea is to separate the various traffic streams so that we can use separate switches that do not influence each other. One NIC will be used for streaming to the internet and (remote) control (this is the only NIC that has a gateway configured). The second one will be used for Dante (audio over IP). This is easy since you configure the Dante Virtual sound-card to use a specific NIC. The third one will be used for NDI. this will be a combination of outgoing NDI towards the screens in the green room, offices, etc. and Inbound NDI from presenter PC's. (vMix Desktop capture).
Does any one know if it is possible to limit (outbound) NDI traffic to the NIC reserved for NDI?
all help is appreciated!
BR Steven
You might be interested in learning about NDI Discovery Server and NDI Access Manager. Check out the video below from 18:40.
NDI
Bind NDI to one NIC
