vMix Call
Iso recordings of Callers with Caller audio only.
Joined: 8/12/2020(UTC) Posts: 18  Location: Bay Area Thanks: 4 times
This is possible to a limited degree using the outputs instead of metacorder, and routing busses to each output from each call, but that limits you to 3 iso recordings per call, where there could be 8 callers. For any client who wants the ability to tweak the edit so they can host the video after the fact, this is a key feature. Also, it eats up busses and outputs that are needed elsewhere.
Another issue is the fact that there are only 7 busses. If I use busses to create talkback channels to each talent, I can only have 7 callers, and I have no busses left for the iso recordings or any other needs.
What are other people doing about this? Should I make a feature request?
Thanks.
vMix Call
