	Instant Replay
	Replay Camera CCTV 60fps
 Joined: 9/30/2020(UTC) Posts: 6  Location: Ho Chi Minh Thanks: 2 times
                Hello! I often use cctv IPC Dahua camera for livestream. Recently I used Replay feature but the system is not getting 60fps but only 29.97fps. I connect via RTSP protocol, the image is still receiving Vmix normally, just not getting 60fps in Replay feature. I tried the other way that via VLC rtsp it got 60fps but the latency is higher than rtsp. With Xsplit software, I see it still can receive full 60fps. Hope you help!
  RTSP 29.97fps [img=https://drive.google.com/file/d/1qvd4yLwvwREYzviVCuk9OhiVggKU4jWw/view?usp=sharing]RTSP[/img]
  VLC RTSP 60fps [img=https://drive.google.com/file/d/19a3kmYd6omdx45mrUVwYU9mbV8hRKPJM/view?usp=sharing]VLC RTSP[/img]
                RTSP 29.97fps  VLC RTSP 60fps
                What Dahua camera model are you using, IPC???????
  Most of them only have a maximum frame rate of 30fps.
              1 user thanked SportsNetUSA.net for this useful post.
                Originally Posted by: SportsNetUSA.net  What Dahua camera model are you using, IPC???????
     I use camera  IPC-HFW5231E-ZE Datasheet:  > 1/2.8” 2Megapixel progressive scan STARVIS™ CMOS > H.265&H.264 triple-stream encoding > 50/60fps@1080(1920×1080) > Smart Detection supported > WDR(120dB), Day/Night(ICR), 3DNR, AWB, AGC, BLC > Multiple network monitoring: Web viewer, CMS(DSS/PSS) & DMSS
                I need help!!! RTSP over VLC with same Camera IPC Dahua: it can receive enough 50fps  RTSP over TCP with same Camera IPC Dahua: just receive 29.97fps
                I need help!!!! RTSP over VLC with same camera IPC Dahua 50fps: Can receive enough 50fps  RTSP over TCP with same camera IPC Dahua 50fps: Just receive 29.97fps
	Instant Replay
