FisheyesProduction
#1 Posted : Friday, September 25, 2020 8:16:57 PM(UTC)
FisheyesProduction
Hi, a really useful feature for small team (self-stream) situations would be an automatic video switcher which triggered when a certain db level on a certain audio input for a certain amount of time.
Settings to determine the db range for switch with a time delay option (to prevent a cough from triggering it for example) and a minimum camera on time would be great. Also to be able to choose your transition type.
Could also feature an option to go to a third camera when when the level of chosen audio channels were both up or when it had been one of the primary cameras for a certain amount of time.
I think this would probably be a relatively easy thing to implement as the various pieces of functionality are already there. It may even already be be possible to do this with triggers, but I haven't looked at it.
Thanks,
Ben
#2 Posted : Friday, September 25, 2020 8:59:37 PM(UTC)
Always worth to look first !
There is a OnAudioMeterDBxx trigger !
thanks 2 users thanked doggy for this useful post.
FisheyesProduction on 9/25/2020(UTC), someblue on 9/26/2020(UTC)
xemles
#3 Posted : Friday, September 25, 2020 11:10:51 PM(UTC)
xemles
France, Metropolitan
It is possible with the "OnAudioMeterDB" trigger as doggy said, but it isn't that advanced.
I found on that forum a few months back a program I use on a daily basis for multicam like that, I would recommend you to try it out, it might be what you're looking for: https://w.np.co.nz/software
thanks 1 user thanked xemles for this useful post.
