Joined: 9/22/2020(UTC) Views messages in topic : 1  Location: Devon
Hi, Is anyone using the Aver CAM520 pro PTZ camera with vMix? It supports VISCA over IP, but I can’t seem to connect and control it with any of the vMix device types in the PTZ drop down menu, other than the ‘plug and play’ UVC PTZ, but this doesn’t control the zoom.
I’m using the USB for the capture, and a network connection with default IP of 192.168.1.168 for the control... has anyone successfully got the controls working and how did you do it?
Many thanks, John
