NTSC
#1 Posted : Tuesday, September 22, 2020 5:24:30 AM(UTC)
NTSC
I am trying to set up a four box interview and having a heck of a time. I used the four box virtual set with a background as a template. I don't want a background though, I want all four inputs squared up against each other. It's all but impossible do that quickly or easily using the positioning tools.
Is there an easy way to add all four sources and line them up drag and drop to be 2x2 vs these stupid numerical sliders that never get the source where I want it?
Is there an existing template I can download?
And for the love of god, please add an undo feature when editing scenes.
I must be missing something. This can't be that hard to set up.
#2 Posted : Tuesday, September 22, 2020 5:35:40 AM(UTC)
this video addresses a little bit of math regarding size and positions :-)
CrimsonAvenger
#3 Posted : Tuesday, September 22, 2020 6:31:09 AM(UTC)
CrimsonAvenger
Undo +1
Idiot-proof simple layouts +1
You’ll be torn to shreds for not learning the software before you asked a question. Even though everyone is so “helpful”.
Learn to code. You have been warned.
Simsyuk
#4 Posted : Tuesday, September 22, 2020 12:08:02 PM(UTC)
Simsyuk
Was thanked: 24 time(s) in 19 post(s)
Not sure if this is any help to you!
Guest 4.rar (115kb) downloaded 15 time(s).
mavik
#5 Posted : Tuesday, September 22, 2020 6:19:03 PM(UTC)
mavik
Was thanked: 193 time(s) in 173 post(s)
Add a blank shot
double click on it
goto multiview
select a 4 shot template
select the source for each area from the drop down.
ready
jtr210
#6 Posted : Wednesday, September 23, 2020 6:44:31 AM(UTC)
jtr210
Mavik's instructions are right on.
To be even more specific:
Add Input
Choose "Colour"
Choose either Transparent or Colour (black is perfect)
Click on the gear icon for that Input
Multi View
On the right side there are a bunch of pre-made templates (in blue, red and other colors)
Scroll down to find the 1, 2, 3, 4 template with four colors
Choose what Inputs you want in each numbered box from the drop down menus right there.
Voila!
This is a powerful feature you can use for many many things.
NTSC
#7 Posted : Thursday, September 24, 2020 8:21:05 AM(UTC)
NTSC
Thanks I downloaded this and it will get me started. I am going to make each guest fill the 25% of the screen so everyone has max real estate
NTSC
#8 Posted : Thursday, September 24, 2020 8:25:17 AM(UTC)
NTSC
Add Input
Choose "Colour"
Multi View
Voila!
Great. Thanks!
Simsyuk
#9 Posted: : Thursday, September 24, 2020 9:00:04 AM(UTC)
Simsyuk
You're welcome, just edit the xml file for the background and positions etc. Personally I prefer the ability to jump to each guest/presenter when they're talking.
