Other way to highlight line of a Datasource
Joined: 2/18/2019(UTC) Posts: 54  Thanks: 5 times Was thanked: 2 time(s) in 2 post(s)
If you select a line in a data source, this line also remains marked, i.e. based on its internal ID. For example, the third record is ALWAYS marked, regardless of what is in it.
I'm looking for a way to keep a record selected using another field? Example: The third line is highlighted, that line contains a 'Name' field, and the name is Smith. Then the data source is changed, Smith is now in line 1. And now line 1 of the data source should be marked for that very reason.
Is that possible?
