RobLambert
#1 Posted : Thursday, September 17, 2020 10:19:53 AM(UTC)
RobLambert
I am wanting to use VMIX desktop capture from my Surface Go.
I use my surface go wirelessly over the internte. Its only connection is a wired USB C port.
I tried connecting the surface go to my studio computer using the USB C port as I don't have any other way and I hoped it might still work. It didn't.
Since I do not have wired ethernet from my surface go i am wondering if there is a way to make the direct wired USB C connection between the hardeware work?
What is the best way to do an NDI desktop capture when all I have is a USB C
I bet this is basic and very simple and my problem is lack of experience. Any help is appreciated.
Rob
mavik
#2 Posted : Thursday, September 17, 2020 5:01:32 PM(UTC)
mavik
I would suggest a USB-C 1G ethernet dongle. Then You can use NDI to transmit.
