emilalex91
#1 Posted : Monday, September 14, 2020 2:07:16 AM(UTC)
emilalex91
Romania
Hello, I'm glad to be here, I'm a new user of vMix.
I would like to request a feature that I believe can be of great use for everyone.
It is about saving the presets but as a project, not only the presets as a single "*.vmix" file but as a whole.
We currently have the option to save our presets and it generates one file "*.vmix" that can be used to take your presets with you on your different machines that you work (laptop,pc,home or at work).
But with the current option, we also need to take all the files that are connected to those presets, pictures, inputs, videos, everything, we need to carefully rename the path to the files in order for the imported preset to work.
Can you make an option like many other programs have, to save the "Project" as either a folder or an archive that can later be used on another machine?
Thank you and I hope my input was of use for all of you!
Great day!
xaver
#2 Posted : Monday, September 14, 2020 2:24:44 AM(UTC)
xaver
We had a similar problem
now we save all the files we need in a project in one folder (with subfolders if it's too much)
after that we "input" the videos and other files
the backup of the folder is copied to the other machine and all (except the hardware inputs from the decklink) is working on the second pc
