cardealpt
#1 Posted : Monday, September 14, 2020 2:03:26 AM(UTC)
cardealpt
I have a setup for hockey match where the main camera is an sony handycam with 50fps. Im capturing it with an avermedia capture board via hdmi.
Im using 2 webcam as fixed angle for replays but they both have 30fps. The replay feature forces every camera to have the same frame rate so i have tried to add them all on inputs as 50fps, 30fps and 60fps. When i change camera it works fine, but when i play the replay, there are stuttering probably due to the frame difference. Is there any way to sync them all so i do smooth replays?
SportsNetUSA.net
#2 Posted : Monday, September 14, 2020 3:28:28 AM(UTC)
SportsNetUSA.net
Are you using a separate SSD for replays on your system? What are your Recording Format settings?
cardealpt
#3 Posted : Monday, September 14, 2020 3:50:36 AM(UTC)
cardealpt
im saving them on my system drive. Its a 1T SSD. I tried almost every framerate, 25, 30, 59,95, 60 but i guess the problem is that i can't manage to record all cameras in sync because of the different frame rate.
I usually save replays at 50MB.
You can see the stuttering on the video:
?t=2426
ask
#4 Posted : Monday, September 14, 2020 8:04:19 AM(UTC)
ask
You should not be recording to your system disk. https://www.vmix.com/hel...?SystemRequirements.html
SportsNetUSA.net
#5 Posted : Monday, September 14, 2020 8:10:06 AM(UTC)
SportsNetUSA.net
I watched the game up to the 30:42 mark and saw several replays. It may look to a viewer who's never seen your games that the replays are being purposely paused for effect. On some of them it works quite well, even though I know that's not what you're trying to do.
The replays are always from the webcams, correct? So it would seem if Recording Settings in Instant Replay are set to the webcams optimum frame rate, then the replays should record and playback properly.
I think the problem could be your system can't handle the replays since everything is running on the system drive. Anyway you could even borrow an SSD to test out Instant Replay on a separate drive?
ralston
#6 Posted : Monday, September 14, 2020 7:12:30 PM(UTC)
ralston
What make/model are your two sideline 30fps cameras?
cardealpt
#7 Posted : Tuesday, September 15, 2020 1:13:22 AM(UTC)
cardealpt
Thanks, i actually didn't know that.
I was trying to use also the main camera to do replays. This might be a problem since the main camera is a 50fps handycam and the webcams work on 30fps and it might lead to sync problems.
I'm going to try a new pc in a few days with dedicated ssd for the replays and will let you know if it fixes the problem.
https://conceptronic.net...?id=1200&linkid=1199
Full HD 1080P30fps
cardealpt
#8 Posted : Tuesday, September 15, 2020 10:24:06 AM(UTC)
cardealpt
Computador i7-10700 | 16GB | SSD 250GB / 1TB
Processador i7-10700 2.9/ 4.8GHz 16MB
Board ASUS Prime Z490-P
Memória Team Elite 2x8GB DDR4 3200
SSD M.2 SATA 250GB Samsung 970 EVO Plus
SSD M.2 SATA 1TB Samsung 970 EVO Plus
Fonte ATX Mars 650W 80 Plus Bronze
Caixa Mars ATX
Gráfica Asus GF GTX1650 TUF OC 4GB GDDR6
Windows 10 Pro 64Bits PT
Is this a good setup for 8 live cameras and 4 replay cameras?
ralston
#9 Posted : Tuesday, September 15, 2020 9:53:05 PM(UTC)
ralston
How are you connecting the side line cameras to vmix ? If the youtube above is using them the quality is pretty good ! for a witness camera
cardealpt
#10 Posted : Tuesday, September 15, 2020 9:55:06 PM(UTC)
cardealpt
They are connected via usb. We are using 20 meters usb extenders.
ralston
#11 Posted : Tuesday, September 15, 2020 10:17:31 PM(UTC)
ralston
and these are the same cameras filming from the side in this video ? Pretty impressive. I am looking for some fixed HD cameras that are not too expensive
cardealpt
#12 Posted : Wednesday, September 16, 2020 12:50:57 AM(UTC)
cardealpt
Yes, they are the fixed cameras close to the goals. They cost around 30€ in Portugal.
cardealpt
#13 Posted : Friday, September 25, 2020 6:09:30 AM(UTC)
cardealpt
I'm using a new computer with recommend hardware on vmix site and using a ssd disk dedicated for replays.
My project is 50p, ive two handycam 50p and two fixed webcam 30p but i add them as 50p so i can put them all on instant replay.
The 50p cameras run smoothly on replays but the 30p cameras play very fast and stutter 1 or 2 times
SportsNetUSA.net
#14 Posted : Friday, September 25, 2020 9:43:07 AM(UTC)
SportsNetUSA.net
Your AMDIS 1080P Full HD Webcams have specs for 30fps with USB 2.0 connectivity. At 50fps they probably will have problems.
Have you tried using MJPG under the Video Format Dropdown?
cardealpt
#15 Posted : Friday, September 25, 2020 5:59:24 PM(UTC)
cardealpt
I know I am not supposed to input the webcams as 50p but the instant replay cameras must be in the same format. I'm using mjpg
