Rank:: Newbie
Joined: 9/10/2020(UTC) Posts: 9  Location: Belfast Was thanked: 1 time(s) in 1 post(s)
1. The current system allows me to create and rename virtual inputs from my PTX cameras and this is a great feature. However when I go back to my original camera inout to make minor adjustments, I'm not able to see the friendly names of the camera positions but only their number - a number which, correctly, changes if I rearrange the inputs in the icon screen. It would be very helpful if the names could be displayed as well/instead of the numbers to allow easy updating.
2. It would be helpful for virtual inputs to carry over the PTZ Device type with which they are created. Currently they are created with Device Type None and have to be selected individually or adjusted from the original input.
3. In association with 2, an Update current Input button would be great so I could go to a virtual input, adjust it and save the adjustments quickly
