Papo
#1 Posted : Wednesday, September 9, 2020 12:16:16 PM(UTC)
Papo
Peru
Greetings to all, I am creating a dll, but I would like to know in what output size the vmix is being used, example HD 1080 29.97p or maybe another size, so that my dll can work freely or I have to make certain adjustments, it's important to me already that my control is designed to work in 1080p but if the vmix is set to a smaller output size then it would not look good, the positions would be fine by the margins but the sizes there would be a problem, so I need to know the size of the project that is vmix is currently working, regards
#2 Posted : Wednesday, September 9, 2020 5:25:57 PM(UTC)
No Idea what you are trying to explain but the data you want can be found in the user.config file (xml)
Papo on 9/10/2020(UTC)
