Martin Block
#1 Posted : Friday, September 4, 2020 11:09:05 AM(UTC)
Martin Block
Rank:: Advanced Member
Philippines
I need help.
I am always encountering a unstable connection Only when streaming to Vimeo.
This does not happen always but at least once every stream. The problem is that the unstable connection does not just disappear but forces me to stop/restart my stream In vMix or even end the Live in Vimeo and restart everything.
When I am streaming at 720p 2.5 or higher it always gives me that issue, so I am even down to 720p 1.5 only! (FFMPEG, Use Hardware Encoder is ticked
Still there is no telling why this issue occurs. I am monitoring my CPU usage: all good around 18-19%
Internet: no problem, nothing dropped. Solid 100mbps up and down.
I am trying now to set my stream quality from veryfast to superfast. Would this help?
I have a i9-9900k 3.60 GHz
RTX 2070 Super
32GB RAM
2 x 500GB SSD
Windows 10
I tried to follow all recommendations for vMix: it is set to High Input Performance Mode
Does anybody have a an idea how to resolve this? Or are there issues/special settings with Vimeo? (Vimeo was the one recommending superfast streaming quality settings)
Any help is highly appreciated
Cheers
LiveP
#2 Posted: : Saturday, September 5, 2020 2:45:33 AM(UTC)
LiveP
Singapore
Hi , if you are streaming anything below 4.5mbps
Vimeo always states “ unstable connection “ in orange at the top right of ur page.
If it looks fine it will be okay -
Click on the stream health to see stability of stream.
Try to use 1080P 4.5MBPS at least and it will state good connection.
