chieftaing
#1 Posted : Tuesday, September 1, 2020 2:27:21 AM(UTC)
chieftaing
I'm using triggers more and more, and one case is a single title input that has multiple presets. Because presets cannot be moved "up" or "down" once created, triggers that go to select a title preset have to be really closely in sync with the title presets since the triggers use a 0-based "index" of presets, so adding or deleting a preset can really mess up triggers.
If the title presets (the list at bottom in the title editor) could have a "name" associated with the string, then the trigger could specify the name and changes in the title presets wouldn't mess up the triggers!
Thanks for the great product!
